Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
Since version 12, "Preferences" allows to set the default Summary Statistics in the output of "Distribution". This option should be effective to all platforms.
I'm not sure I understand your suggestion clearly. Can you give an example where the Summary Statistics preference should be used outside of Distibution?
Example - in ANOVA tables, the "Sum of Squares" and "Mean Square" values make these tables wider and consequently more horizontal scrolling is needed (or more printed pages), and because I rarely need these values, they should be presented only upon special request, not as a defaults. Another example are the 95% upper and lower limits of the confidence interval of each mean produced by Fit Y by X.
