JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
Since version 12, "Preferences" allows to set the default Summary Statistics in the output of "Distribution". This option should be effective to all platforms.
I'm not sure I understand your suggestion clearly. Can you give an example where the Summary Statistics preference should be used outside of Distibution?
Example - in ANOVA tables, the "Sum of Squares" and "Mean Square" values make these tables wider and consequently more horizontal scrolling is needed (or more printed pages), and because I rarely need these values, they should be presented only upon special request, not as a defaults. Another example are the 95% upper and lower limits of the confidence interval of each mean produced by Fit Y by X.
