Learn how to build custom Python data connectors and further customize JMP’s Data Connector Framework with the Python Data Connector Demo, available now in the JMP Marketplace!
See how to move from signal modeling to system modeling at the first JMP Aerospace Analytics webinar. Register. June 18, 1 p.m. US Eastern Time.
Since version 12, "Preferences" allows to set the default Summary Statistics in the output of "Distribution". This option should be effective to all platforms.
I'm not sure I understand your suggestion clearly. Can you give an example where the Summary Statistics preference should be used outside of Distibution?
Example - in ANOVA tables, the "Sum of Squares" and "Mean Square" values make these tables wider and consequently more horizontal scrolling is needed (or more printed pages), and because I rarely need these values, they should be presented only upon special request, not as a defaults. Another example are the 95% upper and lower limits of the confidence interval of each mean produced by Fit Y by X.
