Presetting the default-presented statistics under "Preferences"
Since version 12, "Preferences" allows to set the default Summary Statistics in the output of "Distribution". This option should be effective to all platforms.
3 Comments
Jeff_Perkinson
Community Manager
I'm not sure I understand your suggestion clearly. Can you give an example where the Summary Statistics preference should be used outside of Distibution?
AvigdorC
Level III
Example - in ANOVA tables, the "Sum of Squares" and "Mean Square" values
make these tables wider and consequently more horizontal scrolling is
needed (or more printed pages), and because I rarely need these values,
they should be presented only upon special request, not as a defaults.
Another example are the 95% upper and lower limits of the confidence
interval of each mean produced by Fit Y by X.
Ryan_Gilmore
Community Manager
Status changed to: Archived
