  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Platform Preferences
Resetting preferences when changing JMP versions is problematic because pre-existing preferences often get removed. The JSL Set Platform Preferences() command does not run if missing preferences are listed. Additionally, the alert only gives a few messages at a time, so multiple iterations have to be run to work through the list.
  1. Is there a way to only generate the list of preferences set/modified by the user? The command currently seems to publish all preferences (unchanged/default and user set/modified). I primarily only care about the former.
  2. Is there a way to have the JSL commands ignore missing preferences?
  3. Is there a way to get a full list of missing preferences in one alert?
  4. Can JMP provide detailed documentation on which preferences ihave been removed for a major version change?
Why is this idea important?
This will enable aster changeover to and adoption of new versions of JMP.
1 Comment
Sarah-Sylvestre
Level V
