Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
Dear jmp team, I am interested in Passing Bablok regression analysis and it would be grateful if you would consider adding it in jmp. Thanks in advance
I can report that there has been work in this area for JMP 17. Passing Bablock analysis will be available in Fit Y by X, as an option for Bivariate regression analysis. JMP 17 will be available externally in fall of 2022. I also reported this in the primary (linked) item since this was marked as a duplicate item.
