Passing Bablok fitting
Dear jmp team, I am interested in Passing Bablok regression analysis and it would be grateful if you would consider adding it in jmp. Thanks in advance
3 Comments
Jeff_Perkinson
Community Manager
Status changed to: Archived - Duplicate
This is a duplicate request for Passing Bablok. Be sure to add your kudos to that wish.
Audrey_Shull
Status changed to: New
I can report that there has been work in this area for JMP 17. Passing Bablock analysis will be available in Fit Y by X, as an option for Bivariate regression analysis. JMP 17 will be available externally in fall of 2022. I also reported this in the primary (linked) item since this was marked as a duplicate item.
Status changed to: Delivered
@lvierbaum , you will find the Passing Bablok regression in analyse > Fit Y by X (bivariate fit)
