We want to hear your ideas for improving JMP software.
  1. Search: Please search for an existing idea first before submitting a new idea.
  2. Submit: Post your new idea using the Suggest an Idea button. Please submit one actionable idea per post rather than a single post with multiple ideas.
  3. Kudo & Comment Kudo ideas you like, and comment to add to an idea.
  4. Subscribe: Follow the status of ideas you like. Refer to status definitions to understand where an idea is in its lifecycle. (You are automatically subscribed to ideas you've submitted or commented on.)
We consider several factors when looking for what ideas to add to JMP. This includes what will have the greatest benefit to our customers based on scope, needs and current resources. Product ideas help us decide what features to work on next. Additionally, we often look to ideas for inspiration on how to add value to developments already in our pipeline or enhancements to new or existing features.
Option for Conditional filter not to clear selections
In this example, if I changed the date filter, I would want the P30770 selection to stay selected until the P30770 selection is no longer has any qty in the selected time period.
Why is this idea important?
7 Comments
Hi @shampton82, thank you for submitting this idea! We will review it and keep you updated on the status.
shampton82
Level VII
Just to add some more detail to this request as I for some reason didn't fill out all the requested info in the default "wish list template".
  • An additional ask would be that when you toggle conditional on and off the selections wouldn't clear.  Especially if you are toggling from conditional to non-conditional the selections should stay (we know the data is there!).  I usually start with a condition filter and then as needed turn it off if I need to be filtering high level items but don't want lower level filters to get blown out.
  • The original request gets really important with big data sets as having to change a higher level filter can cause big slowdowns (and even crashes) when all the lower level filters get cleared and now all the data tries to show up in something like Graph Builder.
hogi
Level XI
@shampton82 :
seems that other users think along the same line:
different behavior of "clear" for conditional data filters ?
@Sarah-Sylvestre : the other wish is from 2022 - just before JMP17 came out - what is the current status?
shampton82
Level VII
Hey @hogi !
Yep it is the same need as your wish.  Conditional filters are crazy powerful and useful but having the levels clear below a changed "parent" level is super frustrating.  If they can do this for us lets hope they can fit in this as well, another clearing selection annoyance.
Have data filter selections not clear when you need to enter a new filtering ite... - JMP User Commu...
hogi
Level XI
Yes, right, sooooo annoying - and absolutely  no need to reset the selection!
I think I found a solution. I will check ...
didn't find anything ...
Concerning Conditional -> option: don't deselect!!! :
Just 1 person found my wish.
So, maybe we have some luck with the second attempt.
-> I kudoed here
hogi
Level XI
Important:
the new mode should NOT replace the old mode.
There should be a switch in the red triangle menu to activate the cool new behavior - when it's needed.
Or via the preferences: if it is needed frequently.
I often work with data tables where without a filter applied it takes dozens of seconds to recreate the report.
So,  when I found a nut of gold during exploratory data analysis - and want to clear a "parent" setting - while still focusing on the nut on gold (!), it hurts twice:
a) the nut of gold gets hidden again in the haystack (filter selection is lost)
b) it takes several minutes till the report refreshes and I can apply the filter again.
The new setting - activated when needed:
- adjust child filters if a parent filter is changed
- don't remove child filters if a parent filter is cleared via
