JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
Aw man bummer. For what its worth, I think this is important!
Parquet files are really efficient in terms of storage and read times, its particularly nice when you have to transfer data from another platform into JMP or out of JMP into another platform.
If JMP really wants to do big data properly it should be able to read parquet/feather files and import the directly with appropriate compression and column definitions. There's not enough memory to open a file, then compress. And this issue will only get worse.
I also would really like the capability to read directly from a parquet file in to a JMP table. I work regularly with 2GB CSVs (130K rows, 2.5K columns) and have a fairly recent i7 with 64GB RAM laptop. Opening one of these files takes around 5 minutes for the data scan and then another 4 and a half minutes to import the data. This is almost 10 minutes of my time just waiting for JMP to open the file.
Our data system can produce a parquet instead of a csv and the same file is less than 200MB and have encoded the correct data types already in it. When I open one of this parquet files with a single line of code (read_parquet) in pandas it can load it to a dataframe in memory in less than 30 seconds. Lately I am very hesitant to open the files in JMP even if this would be my preference. I can open the file in pandas, do a summary get the info I need in half the time it takes to just open it in JMP.
Having this capability would really be beneficial to people out there doing analysis with bigger files, hope it can be enabled in the close future.
I made an account just to chime in and say the lack of this feature is currently driving users away from jmp in our organization since it is unable to open these files.
Hi all, I have recently developed and put it into the File Exchange -> Add-ins section this "Apache Parquet file importer" add-in: Apache Parquet file importer
It imports interactively .parquet file(s) into corresponding JMP table(s): it works both for a single file and for multiple files (all stores in the same folder)
It requires JMP V17 and a supported Python installation with PyArrow package (and its dependencies).
