One Click
This can be easily accomplished via scripting:dummy plot as input:
Graph Builder( Variables( X( :weight ), Y( :weight ), Y( :height, Position( 1 ) ) ), Elements( Points( X, Y( 1 ), Y( 2 )), Smoother( X, Y( 1 ), Y( 2 ) ) ) );
Names Default To Here(1) myScript = ((current report()[OutlineBox(1)]) << get scriptable object())<< get script; Eval(Substitute(Name Expr(myScript), Expr(Position()), {}));
the idea: replace the position() commands with something innocent.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
