%3CLINGO-SUB%20id%3D%22lingo-sub-331662%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EPiattaforma%20multivariata%20con%20due%20elenchi%20di%20input%20separati%20(Scatterplot)%3C%2FLINGO-SUB%3E%0A%20%20%3CLINGO-BODY%20id%3D%22lingo-body-331662%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%0A%20%20%20%3CP%3ELa%20piattaforma%20multivariata%20accetta%20solo%20un%20elenco%20di%20input.%20Una%20volta%20avviata%20la%20finestra%20di%20dialogo%2C%20le%20correlazioni%20verranno%20calcolate%20su%20tutte%20le%20coppie%20X%20dell'elenco%20di%20input.%20Analogamente%2C%20aggiungendo%20un%20grafico%20a%20dispersione%20all'analisi%20multivariata%2C%20verranno%20visualizzati%20tutti%20i%20grafici%20a%20dispersione%20a%20coppie.%3C%2FP%3E%0A%20%20%20%3CP%3ETuttavia%2C%20in%20molte%20situazioni%2C%20in%20termini%20di%20analisi%20esplorativa%20dei%20dati%2C%20si%20%C3%A8%20interessati%20solo%20a%20%22correlare%22%20e%20creare%20un%20grafico%20a%20dispersione%20su%20un%20certo%20elenco%20di%20variabili%20X%20rispetto%20a%20un%20altro%20elenco%20di%20variabili%20X%20(o%20Y).%20Poich%C3%A9%20tutte%20le%20variabili%20sono%20sempre%20presenti%2C%20scorrere%20l'enorme%20matrice%20di%20grafici%20a%20dispersione%20in%20scenari%20con%20ampi%20set%20di%20dati%20diventa%20un%20compito%20noioso.%3CBR%20%2F%3E%20Gradirei%20vedere%20due%20elenchi%20di%20input%20per%20Multivariate%20con%20correlazioni%20a%20coppie%2Fdiagrammi%20di%20dispersione%20dalle%20variabili%20in%20un%20elenco%20rispetto%20alle%20variabili%20nell'altro%20elenco.%3C%2FP%3E%0A%20%20%3C%2FLINGO-BODY%3E%0A%20%20%3CLINGO-LABS%20id%3D%22lingo-labs-331662%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%0A%20%20%20%3CLINGO-LABEL%3EEsplorazione%20e%20visualizzazione%20dei%20dati%3C%2FLINGO-LABEL%3E%0A%20%20%3C%2FLINGO-LABS%3E%0A%20%0A%3CLINGO-SUB%20id%3D%22lingo-sub-331719%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EOggetto%3A%20piattaforma%20multivariata%20con%20due%20elenchi%20di%20input%20separati%20(grafico%20a%20dispersione)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-331719%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EIl%3CA%20href%3D%22https%3A%2F%2Fwww.jmp.com%2Fsupport%2Fhelp%2Fen%2F15.2%2F%23page%2Fjmp%2Fscatterplot-matrix-2.shtml%23%22%20target%3D%22_self%22%20rel%3D%22noopener%20noreferrer%22%3E%20Matrice%20del%20grafico%20a%20dispersione%3C%2FA%3E%20platform%20nel%20menu%20Graph%20prende%20una%20X%20e%20una%20Y%20list%20e%20crea%20una%20matrice%20di%20scatterplot%20delle%20sole%20coppie%20XY.%20Certo%2C%20non%20riporta%20i%20coefficienti%20di%20correlazione%20ma%20forse%20sar%C3%A0%20utile%20per%20ora.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Multivariate Platform with two separate input lists (Scatterplot)
The Multivariate platform does only accept one input list. Once the dialog is run, correlations will be calculated on all pairwise X from the input list. Similarly when adding a Scatterplot to the multivariate analysis, all pairwise scatterplots will be shown.
However, in many situations there is an interest in only "correlating" and creating a scatterplot on a certain list of X variables versus another list of X (or Y) variables in terms of exploratory data analysis. Since all variables are always there this is a tedious task to scroll through that massive matrix of scatterplots in scenarios of wide datasets.
I'd appreciate to see two input lists for Multivariate with pairwise correlations/scatterplots from the variables in one list versus the variables in the other list.
3 Comments
Jeff_Perkinson
Community Manager
The Scatterplot Matrix platform in the Graph menu takes an X and a Y list and creates a scatterplot matrix of just the XY pairs. Admittedly, it doesn't report correlation coefficients but perhaps it will be helpful for now.
blum_b_1
Level III
Thanks, Jeff, that's what I was looking for. I could achieve the same in Graph Builder, but it takes quite some effort. Admittedly, since Graph Builder is around I do not use any of the other Graphs anymore. I am falling short here as I can tell now.
Ryan_Gilmore
Community Manager
Status changed to: Archived
