%3CLINGO-SUB%20id%3D%22lingo-sub-331662%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EPlataforma%20multivariante%20con%20dos%20listas%20de%20entrada%20independientes%20(diagrama%20de%20dispersi%C3%B3n)%3C%2FLINGO-SUB%3E%0A%20%20%3CLINGO-BODY%20id%3D%22lingo-body-331662%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%0A%20%20%20%3CP%3ELa%20plataforma%20multivariante%20solo%20acepta%20una%20lista%20de%20entrada.%20Una%20vez%20abierto%20el%20cuadro%20de%20di%C3%A1logo%2C%20se%20calcular%C3%A1n%20las%20correlaciones%20de%20todos%20los%20pares%20X%20de%20la%20lista%20de%20entrada.%20De%20igual%20forma%2C%20al%20a%C3%B1adir%20un%20diagrama%20de%20dispersi%C3%B3n%20al%20an%C3%A1lisis%20multivariante%2C%20se%20mostrar%C3%A1n%20todos%20los%20diagramas%20de%20dispersi%C3%B3n%20por%20pares.%3C%2FP%3E%0A%20%20%20%3CP%3ESin%20embargo%2C%20en%20muchas%20situaciones%2C%20solo%20interesa%20correlacionar%20y%20crear%20un%20diagrama%20de%20dispersi%C3%B3n%20con%20una%20lista%20espec%C3%ADfica%20de%20variables%20X%20frente%20a%20otra%20lista%20de%20variables%20X%20(o%20Y)%20en%20t%C3%A9rminos%20de%20an%C3%A1lisis%20exploratorio%20de%20datos.%20Dado%20que%20todas%20las%20variables%20siempre%20est%C3%A1n%20presentes%2C%20resulta%20tedioso%20revisar%20esa%20enorme%20matriz%20de%20diagramas%20de%20dispersi%C3%B3n%20en%20escenarios%20con%20conjuntos%20de%20datos%20amplios.%3CBR%20%2F%3E%20Apreciar%C3%ADa%20ver%20dos%20listas%20de%20entrada%20para%20Multivariado%20con%20correlaciones%2Fdiagramas%20de%20dispersi%C3%B3n%20por%20pares%20de%20las%20variables%20en%20una%20lista%20versus%20las%20variables%20en%20la%20otra%20lista.%3C%2FP%3E%0A%20%20%3C%2FLINGO-BODY%3E%0A%20%20%3CLINGO-LABS%20id%3D%22lingo-labs-331662%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%0A%20%20%20%3CLINGO-LABEL%3EExploraci%C3%B3n%20y%20visualizaci%C3%B3n%20de%20datos%3C%2FLINGO-LABEL%3E%0A%20%20%3C%2FLINGO-LABS%3E
Multivariate Platform with two separate input lists (Scatterplot)
The Multivariate platform does only accept one input list. Once the dialog is run, correlations will be calculated on all pairwise X from the input list. Similarly when adding a Scatterplot to the multivariate analysis, all pairwise scatterplots will be shown.
However, in many situations there is an interest in only "correlating" and creating a scatterplot on a certain list of X variables versus another list of X (or Y) variables in terms of exploratory data analysis. Since all variables are always there this is a tedious task to scroll through that massive matrix of scatterplots in scenarios of wide datasets.
I'd appreciate to see two input lists for Multivariate with pairwise correlations/scatterplots from the variables in one list versus the variables in the other list.
3 Comments
Jeff_Perkinson
Community Manager
The Scatterplot Matrix platform in the Graph menu takes an X and a Y list and creates a scatterplot matrix of just the XY pairs. Admittedly, it doesn't report correlation coefficients but perhaps it will be helpful for now.
blum_b_1
Level III
Thanks, Jeff, that's what I was looking for. I could achieve the same in Graph Builder, but it takes quite some effort. Admittedly, since Graph Builder is around I do not use any of the other Graphs anymore. I am falling short here as I can tell now.
Ryan_Gilmore
Community Manager
Status changed to: Archived
