  • See how to design an experiment, explore factor-response relationships, assess tradeoffs, and ID best settings. Register for Sep. 11 Mastering JMP.
Multiple File Import - Pick File
I would like to suggest the ability to simply 'pick files' from the list in a folder rather than figuring out a filter to apply or moving some files into separate folder.
Use Case: I have a dozen random-ish files in a folder and I want to combine 4 of them. Rather than finding a filter which would allow only those 4 files to be shown, I want to be able to ctrl+click them to build the list manually. (as i click the name populates in the 'select by name or extension box?)
4 Comments
Audrey_Shull
This request is under active development and will be available in a future version of JMP.
JShum
Level II
Agree, check boxes or click/select multiple would be great
hogi
Level XIII
@Sarah-Sylvestre
-> kind of delivered with JMP18
Sarah-Sylvestre
Level V
Status changed to: Delivered
Thanks @hogi! Available in JMP 18.
