  • See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
Make scripts inside a data table editable via JSL
I have been running into this issue recently : I wanted to have a jsl script edit another script that is embedded inside a data table.
Currently, the best I can do is get the script with the message:
dt<< get script () ;
I get the content of the script as a string which I can edit, then I can save it using :
dt<< save script ();
The problem is it can only make a copy and not save to an existing scrîpt. If I use the same name, it will simply add a '2' at the end of the name.
I guess I could save it as number 2, erase the first one, then rename the number 2 to have the original name but this seems a bit tedious and dangerous to do...
 So, what I propose, is a dt<<Edit script (); message.
While we're at it, why not make data table scripts into scriptable objects ? With a way to refer to them, like dt:myscript. Like this they could receive a bunch of messages like all the other objects within JMP.
2 Comments
Ryan_Gilmore
Community Manager
Status changed to: Archived
hogi
Level XIII
Much better than scripting a script as a string - edit it as an expression.
e.g. to get a functionality like dt << Delete Table Variables()
