To visualize my wish I have used the Big Class Data Table and run Fit Model and the Prediction Profiler. Then I have done two changes for a nicer report:
- Changed the label orientation of the x-axes to horizontal,
- In the Effect Tests Table reduced the numbers of decimals in two columns from 4 to 2:
When I now started working on the model and e.g. removed the variable age in the Effect Summary Section and entered it again then the effect of the two settings described above disappeared and the original settings appeared again.
In my real working more complex scenarios apply for which the effort spent and lost is considerable. Is there a way to maintain settings e.g. of axis labels, numbers of decimals and others when developing models e.g. by adding or removing variables?
