Two new column properties
I'd like to see the ability to have warning limits as a column property and equivalence limits as a column property.
  1. Warning limits would show up much like spec limits do on charts (default should be a dashed orange line) entry would look like the spec limit column input box and would be respected in the process screener as it's own columns of % past warning limit and qty past warning limit.
  2. Equivalent limits would be respected by any equivalence test platform as well as the equivalence testing in response screener when you save out a "compare means" table vs having to use a "Practical Difference Portion" of the spec limit assigned to a column.  (like detection limit columns property input box).
  3. Both these column properties could be picked up by the "manage spec limits" platform.
Thanks for condieration!
Steve
1 Comment
Sarah-Sylvestre
Level V
Hi @shampton82, thank you for your suggestion! We have captured your request and will take it under consideration.
