New formula column in response table of Easy DOE platform
I suggest adding the 'new formula columns' option to the response table in the Easy DOE platform. If the response in a DOE is measured repeatedly, it would be beneficial to have the possibility to add all the data to the response table and generate a new formula column for the average response.
The 'new formula columns' option could also find other practical applications in this platform.
3 Comments
Hi @Steffen_Bugge, thank you for your suggestion! We have captured your request and will take it under consideration.
