  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Local Data Filter: fix the bug
☐ cool new feature
☑ could help many users!
☑ removes a „bug“ (unexpected behavior of Jmp)
☐ nice to have
☐ nobody needs it
Sometimes a data filter doesn't do what the user wants it to do - because the filter auto-adjusts the settings by intersecting the filter settings with the values in the current data set.
To solve the issue please add an option to adjust the filter settings to the current data - which can be enabled (like now) and disabled (new).
Why is this idea important?
At the moment, it is the standard behavior of a Data filter to adjust the settings to the current data.
With the new setting, a user will have the chance to prevent Jmp from doing so.
Application cases:
  1. If there is NO overlap between the data filter settings and the content of the current data table, the data filter is removed (?!)
    The expected behavior for 0 overlap is: the filter is not removed - no data is displayed.
    With the new option (disabled), the data filter can be kept like it is and it will be possible to generate a report with "filter = outliers", which shows "0 outliers" if there are 0 outliers: Outlier screening with Jmp Dashboards - how?
  2. If a limit for a continuous variable is outside of the range of values in the current data table, the current version of Jmp automatically adjusts the limit to the data. Data filter: how to specify the limits
    With the new option, the user will have be able to disable this effect if he doesn't want that the filter gets adjusted.
  3. For Modeling Type Multiple Response there is an option to invert the filter (option "None").
    So, the user can list values which should not be displayed.
    If by chance, such a value is not in the current data set, the value will be removed from the filter.
    If the user saves the new setting, the filter setting will be lost:
    https://community.jmp.com/t5/Discussions/Data-filter-how-to-specify-the-limits/m-p/642751
    The new option will give the user the chance to keep the settings.
3 Comments
hogi
Level XIII
Why is this idea important? - additional info:
For Dashboards,
Outlier (:alien:) screening with Jmp Dashboards - how? TS-00046650,
it's "just" annoying that the restriction of the Data Filter is not applied. If the preset does not work, the user can still apply it manually.
But:
With Jmp 17, Data Filter was introduced for Tables/Summary.
Here the issue is much more severe: at the end, there is the wrong result - no Data Filter on the left of a Dashboard where the user can detect and correct the issue.
2 bugs with Tables/Summary
hogi
Level XIII
@mia_stephens
:folded_hands: Column Property: Inclusive Values will fix the issue :)
-> wish can be closed.
Sarah-Sylvestre
Level V
Status changed to: Archived
