  • Sign-in to the JMP Community will be unavailable intermittently Dec. 6-7 due to a system update. Thank you for your understanding!
  • JMP 19 is here! Learn more about the new features.
Label multiple images to show in graph
When a column with images is set as a label, hovering over a datapoint in a graph shows the resp. image. It would be nice if it was possible to do this for multiple images (in different columns). (Setting several columns as label doesn't work, only the image of the first column is shown.)
7 Comments
jpol
Level IV
This would be an excellent feature to help look at multiple wafermaps from test parameters simultaneously.
nascif_jmp
Level VI
@gandi2223 @jpol
We are looking into addressing this requirement with a Graphlet Preset in JMP 16.0.
For JMP 15.0, please take a look at this Add-in and let us know if it works for your needs. Label Viewer: exploring multiple images and text associated with a single visual element using Hover...
gandi2223
Level III
Thanks, @nascif_jmp, this is what I was looking for!
jpol
Level IV
Great Add_In. Works perfectly!
Thank you so much.
Example of mutilple parameter wafermaps shown below
- Philip
nascif_jmp
Level VI
Wow, awesome! Thanks for sharing your screenshot. It looks great!
Jeff_Perkinson
Community Manager
Jeff_Perkinson
Community Manager
Status changed to: Delivered
With the release of JMP 16 the Label Viewer Hover Label will display images from multiple columns.
