%3CLINGO-SUB%20id%3D%22lingo-sub-174900%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EProc%C3%A9dure%20de%20Johnson-Neyman%20(Floodlight)%20et%20Spotlight%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-174900%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EJe%20sugg%C3%A8re%20que%20la%20sortie%20de%20la%20r%C3%A9gression%20inclue%20des%20options%20pour%20le%3CSPAN%3E%20R%C3%A9gions%20Johnson-Neyman%20d'importance%2C%20c'est-%C3%A0-dire%20analyse%20par%20projecteur%20(c'est-%C3%A0-dire%2C%20%C3%A0%20et%20au-dessus%2Fen%20dessous%20de%20quelle%20valeur%20du%20mod%C3%A9rateur%20est%20la%20diff%C3%A9rence%20entre%20les%20niveaux%20de%20la%20variable%20ind%C3%A9pendante%20significative).%20De%20plus%2C%20je%20sugg%C3%A8re%20d'inclure%20des%20options%20pour%20les%20analyses%20de%20projecteur%2C%20bas%C3%A9es%20sur%20des%20r%C3%A9gions%20d%C3%A9finies%20par%20l'utilisateur%20(par%20exemple%2C%20signification%20%C3%A0%20%2B-1%20SD%20de%20la%20moyenne%20du%20mod%C3%A9rateur%20ou%20%C3%A0%20une%20valeur%20particuli%C3%A8re%20du%20mod%C3%A9rateur).%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-174900%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EStatistiques%20et%20analyses%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-560889%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EObjet%20%3A%20Proc%C3%A9dure%20Johnson-Neyman%20(Floodlight)%20et%20Spotlight%20-%20Statut%20chang%C3%A9%20en%20%3A%20Archiv%C3%A9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-560889%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ENous%20archivons%20cette%20demande.%20Si%20cela%20est%20toujours%20important%2C%20veuillez%20commenter%20avec%20des%20d%C3%A9tails%20suppl%C3%A9mentaires%20et%20nous%20rouvrirons.%20Merci!%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-217842%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EObjet%20%3A%20Proc%C3%A9dure%20de%20Johnson-Neyman%20(Floodlight)%20et%20Spotlight%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-217842%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ESi%20vous%20voulez%20que%20votre%20logiciel%20soit%20utilis%C3%A9%20dans%20les%20sciences%20sociales%2C%20en%20particulier.%20psychologie%2C%20ce%20serait%20une%20caract%C3%A9ristique%20essentielle.%20En%20g%C3%A9n%C3%A9ral%2C%20la%20possibilit%C3%A9%20de%20suivre%20une%20interaction%20impliquant%20une%20variable%20continue%20pour%20effectuer%20une%20analyse%20%22pentes%20simples%22%20ou%20%22effets%20simples%22%20dans%20laquelle%2C%20au%20minimum%2C%20l'utilisateur%20peut%20soit%20sonder%20la%20pente%20d'une%20droite%20%C3%A0%20diff%C3%A9rentes%20valeurs%20d'un%20autre%20pr%C3%A9dicteur%20(et%20obtenir%20des%20pentes%20avec%20SE)%20et%20mieux%20encore%2C%20pr%C3%A9voir%20des%20contrastes%20entre%20ces%20pentes.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Johnson-Neyman Procedure (Floodlight) and Spotlight
I suggest that the output for regression include options for the Johnson-Neyman regions of significance—i.e., floodlight analysis (i.e., at and above/below what value of the moderator is the difference between levels of the independent variable significant). In addition, I suggest including options for spotlight ananyses, based on regions defined by the user (e.g., significance at +-1 SD from the mean of the moderator or at a particular value of the moderator).
2 Comments
michaelyoung
Level II
If you want your software to be used in the social sciences, esp. psychology, this would be a critical feature.  In general, the ability to follow up an interaction involving a continuous variable to conduct a "simple slopes" or "simple effects" analysis in which, at a minimum, the user can either probe the slope of a line at different values of another predictor (and obtain slopes with SEs) and even better, provide contrasts between these slopes.
Ryan_Gilmore
Community Manager
Status changed to: Archived
