%3CLINGO-SUB%20id%3D%22lingo-sub-174900%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EJohnson-Neyman-Verfahren%20(Flutlicht)%20und%20Spotlight%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-174900%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EIch%20schlage%20vor%2C%20dass%20die%20Ausgabe%20f%C3%BCr%20die%20Regression%20Optionen%20f%C3%BCr%20enth%C3%A4lt%3CSPAN%3E%20Signifikanzregionen%20nach%20Johnson-Neyman%20%E2%80%93%20dh%20Flutlichtanalyse%20(dh%20bei%20und%20%C3%BCber%2Funter%20welchem%20Wert%20des%20Moderators%20ist%20die%20Differenz%20zwischen%20den%20Stufen%20der%20unabh%C3%A4ngigen%20Variablen%20signifikant).%20Au%C3%9Ferdem%20schlage%20ich%20vor%2C%20Optionen%20f%C3%BCr%20Spotlight-Analysen%20einzubeziehen%2C%20basierend%20auf%20vom%20Benutzer%20definierten%20Regionen%20(z.%20B.%20Signifikanz%20bei%20%2B-1%20SD%20vom%20Mittelwert%20des%20Moderators%20oder%20bei%20einem%20bestimmten%20Wert%20des%20Moderators).%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-174900%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EStatistik%20und%20Analytik%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-560889%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20Johnson-Neyman-Verfahren%20(Floodlight)%20und%20Spotlight%20%E2%80%93%20Status%20ge%C3%A4ndert%20in%3A%20Archiviert%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-560889%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EWir%20archivieren%20diese%20Anfrage.%20Wenn%20dies%20immer%20noch%20wichtig%20ist%2C%20kommentieren%20Sie%20bitte%20mit%20zus%C3%A4tzlichen%20Details%20und%20wir%20werden%20wieder%20%C3%B6ffnen.%20Danke%20sch%C3%B6n!%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-217842%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Johnson-Neyman-Verfahren%20(Flutlicht)%20und%20Spotlight%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-217842%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EWenn%20Sie%20m%C3%B6chten%2C%20dass%20Ihre%20Software%20in%20den%20Sozialwissenschaften%20verwendet%20wird%2C%20insb.%20Psychologie%2C%20dies%20w%C3%A4re%20ein%20kritisches%20Merkmal.%20Im%20Allgemeinen%20die%20F%C3%A4higkeit%2C%20eine%20Interaktion%20mit%20einer%20kontinuierlichen%20Variablen%20zu%20verfolgen%2C%20um%20eine%20Analyse%20%E2%80%9Eeinfacher%20Steigungen%E2%80%9C%20oder%20%E2%80%9Eeinfacher%20Effekte%E2%80%9C%20durchzuf%C3%BChren%2C%20bei%20der%20der%20Benutzer%20mindestens%20entweder%20die%20Steigung%20einer%20Linie%20bei%20unterschiedlichen%20Werten%20eines%20anderen%20Pr%C3%A4diktors%20untersuchen%20kann%20(und%20Steigungen%20mit%20SEs%20erhalten)%20und%20noch%20besser%2C%20stellen%20Sie%20Kontraste%20zwischen%20diesen%20Steigungen%20bereit.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Johnson-Neyman Procedure (Floodlight) and Spotlight
I suggest that the output for regression include options for the Johnson-Neyman regions of significance—i.e., floodlight analysis (i.e., at and above/below what value of the moderator is the difference between levels of the independent variable significant). In addition, I suggest including options for spotlight ananyses, based on regions defined by the user (e.g., significance at +-1 SD from the mean of the moderator or at a particular value of the moderator).
2 Comments
michaelyoung
Level II
If you want your software to be used in the social sciences, esp. psychology, this would be a critical feature.  In general, the ability to follow up an interaction involving a continuous variable to conduct a "simple slopes" or "simple effects" analysis in which, at a minimum, the user can either probe the slope of a line at different values of another predictor (and obtain slopes with SEs) and even better, provide contrasts between these slopes.
Ryan_Gilmore
Community Manager
Status changed to: Archived
