%3CLINGO-SUB%20id%3D%22lingo-sub-174900%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EProcedura%20Johnson-Neyman%20(Floodlight)%20e%20Spotlight%3C%2FLINGO-SUB%3E%0A%20%20%3CLINGO-BODY%20id%3D%22lingo-body-174900%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%0A%20%20%20%3CP%3ESuggerisco%20che%20l'output%20della%20regressione%20includa%20opzioni%20per%20le%20%3CSPAN%3Eregioni%20di%20significativit%C3%A0%20di%20Johnson-Neyman%2C%20ovvero%20l'analisi%20floodlight%20(ovvero%2C%20al%20di%20sopra%2Fal%20di%20sotto%20di%20quale%20valore%20del%20moderatore%20si%20verifica%20la%20differenza%20tra%20i%20livelli%20della%20variabile%20indipendente%20significativa).%20Inoltre%2C%20suggerisco%20di%20includere%20opzioni%20per%20analisi%20spotlight%2C%20basate%20su%20regioni%20definite%20dall'utente%20(ad%20esempio%2C%20significativit%C3%A0%20a%20%2B-1%20DS%20dalla%20media%20del%20moderatore%20o%20a%20un%20valore%20specifico%20del%20moderatore).%3C%2FSPAN%3E%3C%2FP%3E%0A%20%20%20%3CBR%20%2F%3E%0A%20%20%20%3CBR%20%2F%3E%0A%20%20%3C%2FLINGO-BODY%3E%0A%20%20%3CLINGO-LABS%20id%3D%22lingo-labs-174900%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%0A%20%20%20%3CLINGO-LABEL%3EModellazione%20predittiva%20e%20apprendimento%20automatico%3C%2FLINGO-LABEL%3E%0A%20%20%3C%2FLINGO-LABS%3E%0A%20%0A%3CLINGO-SUB%20id%3D%22lingo-sub-560889%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Procedura%20Johnson-Neyman%20(Floodlight)%20e%20Spotlight%20-%20Stato%20cambiato%20in%3A%20Archiviato%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-560889%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EStiamo%20archiviando%20questa%20richiesta.%20Se%20questo%20%C3%A8%20ancora%20importante%2C%20commenta%20con%20ulteriori%20dettagli%20e%20riapriremo.%20Grazie!%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-217842%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERi%3A%20Procedura%20Johnson-Neyman%20(Floodlight)%20e%20Spotlight%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-217842%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ESe%20vuoi%20che%20il%20tuo%20software%20venga%20utilizzato%20nelle%20scienze%20sociali%2C%20esp.%20psicologia%2C%20questa%20sarebbe%20una%20caratteristica%20fondamentale.%20In%20generale%2C%20la%20capacit%C3%A0%20di%20seguire%20un'interazione%20che%20coinvolge%20una%20variabile%20continua%20per%20condurre%20un'analisi%20%22pendenze%20semplici%22%20o%20%22effetti%20semplici%22%20in%20cui%2C%20come%20minimo%2C%20l'utente%20pu%C3%B2%20sondare%20la%20pendenza%20di%20una%20linea%20a%20diversi%20valori%20di%20un%20altro%20predittore%20(e%20ottenere%20pendii%20con%20SE)%20e%20ancora%20meglio%2C%20fornire%20contrasti%20tra%20questi%20pendii.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Johnson-Neyman Procedure (Floodlight) and Spotlight
I suggest that the output for regression include options for the Johnson-Neyman regions of significance—i.e., floodlight analysis (i.e., at and above/below what value of the moderator is the difference between levels of the independent variable significant). In addition, I suggest including options for spotlight ananyses, based on regions defined by the user (e.g., significance at +-1 SD from the mean of the moderator or at a particular value of the moderator).
2 Comments
michaelyoung
Level II
If you want your software to be used in the social sciences, esp. psychology, this would be a critical feature.  In general, the ability to follow up an interaction involving a continuous variable to conduct a "simple slopes" or "simple effects" analysis in which, at a minimum, the user can either probe the slope of a line at different values of another predictor (and obtain slopes with SEs) and even better, provide contrasts between these slopes.
Ryan_Gilmore
Community Manager
Status changed to: Archived
