%3CLINGO-SUB%20id%3D%22lingo-sub-174900%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EProcedimiento%20Johnson-Neyman%20(Floodlight)%20y%20Spotlight%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-174900%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ESugiero%20que%20la%20salida%20para%20la%20regresi%C3%B3n%20incluya%20opciones%20para%20el%3CSPAN%3E%20Regiones%20de%20Johnson-Neyman%20de%20importancia%2C%20es%20decir%2C%20an%C3%A1lisis%20de%20reflector%20(es%20decir%2C%20en%20y%20por%20encima%2Fpor%20debajo%20de%20qu%C3%A9%20valor%20del%20moderador%20es%20la%20diferencia%20entre%20los%20niveles%20de%20la%20variable%20independiente%20significativa).%20Adem%C3%A1s%2C%20sugiero%20incluir%20opciones%20para%20an%C3%A1lisis%20destacados%2C%20basados%20en%20regiones%20definidas%20por%20el%20usuario%20(p.%20ej.%2C%20significaci%C3%B3n%20a%20%2B-1%20SD%20de%20la%20media%20del%20moderador%20o%20en%20un%20valor%20particular%20del%20moderador).%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-174900%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EEstad%C3%ADsticas%20y%20Anal%C3%ADtica%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-217842%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Procedimiento%20de%20Johnson-Neyman%20(Floodlight)%20y%20Spotlight%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-217842%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ESi%20desea%20que%20su%20software%20se%20utilice%20en%20las%20ciencias%20sociales%2C%20esp.%20psicolog%C3%ADa%2C%20esta%20ser%C3%ADa%20una%20caracter%C3%ADstica%20cr%C3%ADtica.%20En%20general%2C%20la%20capacidad%20de%20seguir%20una%20interacci%C3%B3n%20que%20involucre%20una%20variable%20continua%20para%20realizar%20un%20an%C3%A1lisis%20de%20%22pendientes%20simples%22%20o%20%22efectos%20simples%22%20en%20el%20que%2C%20como%20m%C3%ADnimo%2C%20el%20usuario%20puede%20probar%20la%20pendiente%20de%20una%20l%C3%ADnea%20en%20diferentes%20valores%20de%20otro%20predictor%20(y%20obtener%20pendientes%20con%20SEs)%20y%20a%C3%BAn%20mejor%2C%20proporcionar%20contrastes%20entre%20estas%20pendientes.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Johnson-Neyman Procedure (Floodlight) and Spotlight
I suggest that the output for regression include options for the Johnson-Neyman regions of significance—i.e., floodlight analysis (i.e., at and above/below what value of the moderator is the difference between levels of the independent variable significant). In addition, I suggest including options for spotlight ananyses, based on regions defined by the user (e.g., significance at +-1 SD from the mean of the moderator or at a particular value of the moderator).
2 Comments
michaelyoung
Level II
If you want your software to be used in the social sciences, esp. psychology, this would be a critical feature.  In general, the ability to follow up an interaction involving a continuous variable to conduct a "simple slopes" or "simple effects" analysis in which, at a minimum, the user can either probe the slope of a line at different values of another predictor (and obtain slopes with SEs) and even better, provide contrasts between these slopes.
Ryan_Gilmore
Community Manager
Status changed to: Archived
