%3CLINGO-SUB%20id%3D%22lingo-sub-85398%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EJSL%20obteniendo%20acceso%20al%20archivo%20de%20Excel%20en%20Sharepoint%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-85398%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3ELe%20he%20preguntado%20a%20la%20comunidad%20c%C3%B3mo%20podr%C3%ADa%20escribir%20c%C3%B3digo%20JSL%20para%20solucionar%20nuestro%20sistema%20de%20puntos%20compartidos.Tengo%20un%20c%C3%B3digo%20JSL%20para%20abrir%20la%20ventana%20%22abrir%20archivo%22%2C%20pero%20el%20campo%20para%20completar%20autom%C3%A1ticamente%20el%20nombre%20del%20archivo%20en%20el%20campo%20del%20archivo%20parece%20ser%20un%20poco%20extra%C3%B1o.Puedo%20colocar%20el%20hiperv%C3%ADnculo%20correcto%20en%20el%20campo%2C%20pero%20se%20cambia%20la%20puntuaci%C3%B3n%20en%20el%20nombre%20del%20archivo.%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FDiscussions%2FJSL-obtaining-access-to-excel-file-in-sharepoint%2Fm-p%2F85115%2Fhighlight%2Ftrue%23M38119%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.jmp.com%2Ft5%2FDiscussions%2FJSL-obtaining-access-to-excel-file-in-sharepoint%2Fmp%2F85115%2Fhighlight%2Ftrue%23M38119%3C%2FA%3E%3C%2FP%3E%3CP%3EConsulte%20mi%20discusi%C3%B3n%20de%20soporte%20de%20la%20comunidad%20vinculada%20anteriormente.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-85398%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EAcceso%20a%20los%20datos%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Esecuencias%20de%20comandos%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EInterfaz%20de%20usuario%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-560913%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20JSL%20obteniendo%20acceso%20al%20archivo%20de%20Excel%20en%20Sharepoint%20-%20Estado%20cambiado%20a%3A%20Archivado%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-560913%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EEstamos%20archivando%20esta%20solicitud.%20Si%20esto%20sigue%20siendo%20importante%2C%20comente%20con%20detalles%20adicionales%20y%20volveremos%20a%20abrir.%20%C2%A1Gracias!%3C%2FLINGO-BODY%3E
JSL obtaining access to excel file in sharepoint
I have asked the community how I might write JSL code to work around our sharepoint system.  I have some JSL code for getting the "open file" window to open but the field for auto-populating the file name into the file field seems to be a bit weird.  I can put the correct hyperlink into the field but punctuation in the file name is changed.
https://community.jmp.com/t5/Discussions/JSL-obtaining-access-to-excel-file-in-sharepoint/m-p/85115/...
Please see my community support discussion linked above.
4 Comments
Ryan_Gilmore
Community Manager
Status changed to: Archived
StarfruitBob
Level VI
+1 to this still being important.
FN
Level VI
Still archived
