  • Sign-in to the JMP Community will be unavailable intermittently Dec. 6-7 due to a system update. Thank you for your understanding!
  • JMP 19 is here! Learn more about the new features.
JSL Script for converting excel files to text files without opening the excel files
I'd like to request an ability to convert an excel file to a text file through JSL without having to open the excel file first.  This would greatly speed up daily reports that have to reference excel files (fyi: an excel file currently takes 30 seconds to open but the same file as a text CSV file opens in a second).  Something along the lines of Copy(source, tabs, starting row, starting col, ending row, ending col).
This was brought up in this discussion post as well:
https://community.jmp.com/t5/Discussions/Save-xlsx-to-csv-file/m-p/36763
Thanks for considering it!
Steve
4 Comments
SamGardner
Level VII
Status changed to: Needs Info
Steve, thanks for the input and the suggestion. Could you share an example XLSX file that takes a long time to import versus import as a CSV.  We can investigate that.
I feel like a direct XLSX -> text import might be challenging.  Under the hood, XLSX is a compressed file with an XML structure, see https://docs.microsoft.com/en-us/openspecs/office_standards/ms-xlsx/f780b2d6-8252-4074-9fe3-5d7bc483...
but that XML structure and the data format can be hard to work with.
Another community discussion around this topic:
https://community.jmp.com/t5/Discussions/Help-With-XML-Parsing/td-p/86614
shampton82
Level VII
Thanks for the input Sam and those links!
Let me clean up those files so I can share them and I'll get them over to you this weekend.
SamGardner
Level VII
