Improvements to Power Explorer Platform
What inspired this wish list request? While using the Power Explorer platform, I find myself having to jump back and forth between different input boxes as I try and examine different operation conditions due to the fact that few of the boxes can be locked.  This makes for a frustrating and ineffective user experience.  Also, there are some one and two sample test I'd like to do power analysis for an equivalence test but there is currently no option.
  • Add Power to the "Solve for" drop down options
  • Add Margin of Error to the "Solve for" drop down options
  • Only allow what has been selected in the "Solve for" drop down  to change as the other input boxes are updated
  • Add the ability to lock the ratio between G1 and G2 sample sizes
  • For Sample Counts per Unit, change the "Assumed Ratio of Group Counts per Unit" inputs to a single input of the ratio of group 1 to group 2 defect counts per unit.
  • Add in one and two sample Equivalence test for Proportions and Counts
Why is this idea important? The Power Explorer platform is a key platform but is hard to use and less intuitive than the Minitab equivalent(though it does have more and better capability!).
Thanks for considering this!
Steve
3 Comments
SarahGilyard
These are interesting suggestions. Thank you for posting shampton82
SarahGilyard
Status changed to: Under Consideration
Hi  shampton82  .  In JMP 19 we have added ability to address the following feature request:
We will continue investigating your remaining requests for improving the Sample Size Explorer platforms. Thank you!
shampton82
Level VII
Thanks @SarahGilyard, appreciate all the updates you've been doing on Wish list items.
