  • See how to use JMP Pro to analyze and predict using entire data set rather than selected points in a curve. Register for Nov. 6 Mastering JMP.
Improvements to Power Explorer Platform
What inspired this wish list request? While using the Power Explorer platform, I find myself having to jump back and forth between different input boxes as I try and examine different operation conditions due to the fact that few of the boxes can be locked.  This makes for a frustrating and ineffective user experience.  Also, there are some one and two sample test I'd like to do power analysis for an equivalence test but there is currently no option.
  • Add Power to the "Solve for" drop down options
  • Add Margin of Error to the "Solve for" drop down options
  • Only allow what has been selected in the "Solve for" drop down  to change as the other input boxes are updated
  • Add the ability to lock the ratio between G1 and G2 sample sizes
  • For Sample Counts per Unit, change the "Assumed Ratio of Group Counts per Unit" inputs to a single input of the ratio of group 1 to group 2 defect counts per unit.
  • Add in one and two sample Equivalence test for Proportions and Counts
Why is this idea important? The Power Explorer platform is a key platform but is hard to use and less intuitive than the Minitab equivalent(though it does have more and better capability!).
Thanks for considering this!
Steve
4 Comments
SarahGilyard
These are interesting suggestions. Thank you for posting shampton82
SarahGilyard
Status changed to: Under Consideration
Hi  shampton82  .  In JMP 19 we have added ability to address the following feature request:
We will continue investigating your remaining requests for improving the Sample Size Explorer platforms. Thank you!
shampton82
Level VII
Thanks @SarahGilyard, appreciate all the updates you've been doing on Wish list items.
jszarka
Level V
In what version were you referring to your original comments, @shampton82? When this platform was introduced in JMP 16 (I think), there were elements that I liked in terms of being able to have k-1 elements fixed, and then 'solve' for the kth element. I consider this as a more 'static' case, which can be very useful when you have a specific situation. The current platform in JMP 19 is much more 'dynamic' where you can see the Profiler view with many more features turned on. If I have a specific situation, it is likely much more than I need to consume.
Below is a comparison of the cases. For instance, if I already know my stdev=2, I don't need the dynamic element of how if the stdev was actually 3, that the power would be significantly lower.
Perhaps my adjacent 'wish list' item is to have 2 modes - static and dynamic. In static mode, it could be easy for instance to have 'equal sample sizes for 2 groups' enabled, whereas the dynamic mode could look at a much broader range of options.
