I Optimal design for mixture design
hi, we suggest to set the default criterium at I Optimal for a mixture design when using Custom Design
For the moment, using the custom design platform to create a mixture design, the default is a D Optimal design
For prediction purpose I Optimal will give a smaller integrated prediction variance
regards
François
6 Comments
Hi @francois_berger, thank you for your suggestion! We have captured your request and will take it under consideration.
mia_stephens
francois_berger
Level III
thanks for investigating and let me know if any question
NOTE: do you go to Discovery Europe?
mia_stephens
Status changed to: Not Planned For Now
Hi @francois_berger , it was nice to see you in Sitges!
We've discussed with the developer, and this would be a nontrivial change.
FYI - See this research paper comparing D- and I-Optimal mixture designs: https://www.tandfonline.com/doi/full/10.1080/01621459.2015.1136632
Just to add - the main issue comes when you have constraints, where you need to generate random points in the space. You can do that currently and it does generate I-optimal designs, but we require some further investigation for checking the consistency of the results.
francois_berger
Level III
thank you for the details and for the ref
François
