%3CLINGO-SUB%20id%3D%22lingo-sub-348738%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EColocar%20la%20etiqueta%20por%20defecto%20en%20el%20generador%20de%20gr%C3%A1ficos%20de%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-348738%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3E%C2%BFPuede%20cambiar%20la%20etiqueta%20flotante%20predeterminada%20en%20la%20creaci%C3%B3n%20del%20gr%C3%A1fico%20de%20control%20para%20incluir%20los%20valores%20de%20los%20ejes%20Y%20y%20x%20en%20lugar%20de%20solo%20el%20n%C3%BAmero%20de%20fila%3F%20Actualmente%20necesitas%20usar%20la%20herramienta%20de%20cruz%20o%20asignar%20una%20columna%20como%20etiqueta.%20Sin%20embargo%2C%20la%20opci%C3%B3n%20de%20etiqueta%20se%20desmorona%20si%20crea%20varios%20gr%C3%A1ficos%20utilizando%20la%20nueva%20opci%C3%B3n%20Y%2C%20ya%20que%20las%20etiquetas%20de%20todas%20las%20columnas%20aparecen%20en%20cada%20gr%C3%A1fico%20y%20esto%20solo%20funciona%20para%20los%20gr%C3%A1ficos%20I-MR.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-348738%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EExploraci%C3%B3n%20y%20visualizaci%C3%B3n%20de%20datos%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Hover label default in control chart builder
Can you please change the default hover label in control chart build to include the Y and x axis values vs just the row #.  Currently you need to use the cross hair tool or assign a column as a label.  However, the label option falls apart if you make multiple charts using the new Y option as the labels for all columns show up on each chart and this only works for I-MR charts.
2 Comments
nascif_jmp
Level VI
You mean like this?
X and Y values were added to the CCB hover label in JMP 16.0.
shampton82
Level VII
You got it, looks great!!
