Can you please change the default hover label in control chart build to include the Y and x axis values vs just the row #. Currently you need to use the cross hair tool or assign a column as a label. However, the label option falls apart if you make multiple charts using the new Y option as the labels for all columns show up on each chart and this only works for I-MR charts.
