Hover label default in control chart builder
Can you please change the default hover label in control chart build to include the Y and x axis values vs just the row #.  Currently you need to use the cross hair tool or assign a column as a label.  However, the label option falls apart if you make multiple charts using the new Y option as the labels for all columns show up on each chart and this only works for I-MR charts.
2 Comments
nascif_jmp
Level VI
You mean like this?
X and Y values were added to the CCB hover label in JMP 16.0.
shampton82
Level VII
You got it, looks great!!
