Instantly extract effect sizes, F-ratios, and FDR-adjusted p-values from your models with the Calculate Effects Sizes extension, available now in the JMP Marketplace!
New to JMP? Join us Sept. 23-24 for the Early User Edition of Discovery Summit, tailor-made for new users. Register now for free!
See how to use the JMP Marketplace – Free tools to expand JMP capabilities. Register. July 10, 2 pm US Eastern Time.
@vince_faller , I have JMP PRO 14.3 on windows and here is a screen shot that get namespace names() does return the names. Below is a script that demonstates that show namespaces() with log capture is another alternative.
Names default to here(1);
new namespace("_Test");
new namespace("_Test2");
new namespace("_Test3");
_xx= Words(Trim(Log Capture(show namespaces())), "\!N");
show(_xx);
get namespace names();
Namespace("_Test3") << delete namespace;
Namespace("_Test2") << delete namespace;
Namespace("_Test") << delete namespace;
My first thought is for using namespaces in customer code that we don't want them to have access to. I can encrypt it but if there are flags in place the variable names and values show up. From what it seems I can't even make the variables in a namespace hidden.
__x = 5;
show symbols();
new namespace("__Test",
a = 1,
__hidden = 2,
__hidden_function = function({},
print("hidden")
get namespaces();
I'm just trying to protect proprietary code a little better.
My big use case for JMP 14 is that I'm absolutely loving New Custom Function(). But to use that, it requires the use of a namespace.
