Graph builder column search JMP 19
In JMP 18 it was a lot easier to search through columns when in the graph builder. You could search anything contained within the column name, in any order, and it would pick it up. In JMP 19 this has changed, you have to search column names in the exact way it's presented. This makes it difficult to filter when you have thousands of columns with complicated names.
Make column search simpler when in the graph builder in JMP19 - allow strings of characters in any order
Why is this idea important?
Ease of use in graph builder.
4 Comments
hogi
Level XIII
The JMP18 option is still available as "contains term" - together with many new options:
hogi
Level XIII
@JMP Developers (Data filter team) - please contact JMP Developers (Data Grid team)
... and copy the new flexibility.
e.g. :
data filters, new option: "not"
hogi
Level XIII
ah, hi @JMP . sorry.
Status changed to: Delivered
Hello! As Hogi notes, if you change JMP 19 to use Contains Terms for the search field, then it works as JMP 18 did. I am marking this as Delivered, but if this does not address your request please let me know.
