Graph builder bar chart data label control
I'd like to see the ability to set the font, location in the bar, and decimal format in the graph builder platform for the bar chart data labels.  Right now the only option is to change the default Font setting for all charts to get the data fonts to be what you need.  This need to be able to be changed on a per graph basis along with the additional formatting options.
14 Comments
hogi
Level XIII
Besides Bar graphs and Heatmaps, please also add a label control for Pointp plots.
@Sarah-Sylvestre, couldy you please check the topic - better submit separate wishes for the other plot types?
Change (Increase/Decrease) Font size for Value Labels in Graph Builder charts @tajrida
WINDOWS 10 > JMP 17.2 > Graph Builder > Scatter Plot > Dynamic Cluster Annotation @Thierry_S
Changing the font size of point labels in a Contour Plot @DMR
hogi
Level XIII
hogi
Level XIII
hogi
Level XIII
Another great feature which should be added:
A control which column is used as Label.
At the moment, Graph builder takes this setting from the Table settings.
So, if a label is added to one graph, it will automatically show up in ALL graphs.
As soon as you have 2 different labels for 2 different graphs, this leads to a conflict.
Both labels will show up in both graphs.
The idea: a sepecial command in Graph Builder which can be used to specify the labels for THIS graph.
Actually: a copy of the functionality which is available for hover labels.
Cool side effect: This will also allow to use Transform Columns as Labels (!!!)
Label columns don't have to be added to the main data table.
example: Graph Builder, stack bar with N as summary and % of factor as label
