  • See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
Graph Builder: option to lock the Tick Spacing (Heatmap cell size)
☐ cool new feature
☑ could help many users!
☑ fixes something that feels like a „bug“
☐ nice to have
☐ nobody needs it
#myTop10_2022
#myTop10_2023
#myTop10_2024
#myTop10_2025
#myTop10_2026
short:
against issue like this one:
long:
View more...
Heatmaps are great to display variations of a value depending on 2 input variables.
prominent use case: measured values vs. x/y position (e.g. chips on a wafer)
Unfortunately, Heatmaps use the minor Tick spacing to determine the size of the individual "tiles".
This leads to a which actually feels like a bug for many Jmp users - the issue:
The tick settings (and with them: the Heatmap tile size!) are automatically adjusted whenever the user changes the axis range by dragging the axis or by zooming with the magnifier tool:
Some problem using Heatmap
Concerning axis adjustments by dragging, @jules 's suggestion helps: hold down SHift while changing the axis scaling.
But it just helps when you drag one end of the axis - if you want to zoom out by grabbing the axis and moving it away from the plot, you will ruin you plot - with and without pressing Shift. Same issue
https://community.jmp.com/t5/Discussions/Some-problem-using-Heatmap/m-p/571751/highlight/true#M78136
An option for GraphBuilder/Heatmap to forces JMP to set the tick spacing fixed.
This will allow users to keep the tick spacing exactly as it was defined by the user.
Why is this idea important?
Under the line: tiny change of the program - tremendous improvement for the users.
maybe there are some users who don't need it - or: some users who don't know yet that they need it :)
No longer destroyed plots after adjusting the axis range/zoom :)
  • most important use case: "1x1"
    (for chip wafer maps in Semiconductor Industry)
    error 1) Jmp clusters multiple chips into one cell by increasing minot tick step size to > 0 -> individual outliers get averaged out!
    error 2) Jmp invents empty "sub-Chips" by automatically changing minor tick step size to < 1:
    To be on the safe side, cautious users abandon the Heatmap style and plot wafermaps as Points:
    either with mainly white area around the "points" - which makes it hard to get the actual info:
    or with overlapping points -> dangerous, almost as bad as the clustering issue (#1) (!)
16 Comments
paunzihunter
Level I
trying to visualize and work with wafer maps in jmp, this feature would definitely be a huge benefit!
hogi
Level XIII
:folded_hands: Column Property: Inclusive Values will reduce the issue [if batch assign like "-100 ... 100 (steps of 1)" will be added.
Nevertheless, I still hope that this option will make it into one of the future releases.
So tiny - so powerful!
hogi
Level XIII
@Jeff_Perkinson
as discussed yesterday.
Such a tiny change of the GUI, such a huge improvement for the users of Graph Builder!
If somebody fears that the axis menu gets too crowded:
The Checkbox could be hidden behind a  CTRL/Alt/Shift + click/select/double click/right click
hogi
Level XIII
for very simple plots (without aggregation), I added a Script to the GraphBuilder Toolbar which does the job.
BHarris
Level VII
We use heatmaps like this all the time, but almost always use nominal variables for the axes.
To me it seems like "lock scales" under the Graph Builder red triangle would be perfect to prevent this, but it doesn't seem to work for that.  =(
hogi
Level XIII
yes, something like lock scales would be great. If it locks the scales : )
issues with nominal values:
  1. poor( often:  non-acceptable) quality of the tick labels:
  2. the numbers loose their "meaning"
    e.g. if there are no data points at 50/60, this should be visible as a gap on the x axis.
    With nominal values, the gap is removed: after 40 follows 70:
    For this part of the issue, Column Property: Inclusive/forced Values (:green_heart:)  in JMP19 will be a huge improvement.
