Graph Builder new option: global fit
☑ cool new feature
☑ could help many users!
☑ removes something that feels like a „bug“
☐ nice to have
☐ nobody needs it
Via the variables settings in Graphbuilder a user can disable some variables for a specific plot style.
Extremely useful!!
... but it could be even better. At the moment, not ALL variables are listed, e.g. X / Y Group and Wrap are missing.
missing: Wrap, X Group, Y Group ?!?!?
Add checkboxes for the missing variables - to give the user the chance to disable them.
Why is this idea important?
If a user uses Wrap to split a plot into several subplots -  at the moment, there is no possibility to generate a COMMON FIT (with all data points) and display it an all subplots. such a common fit could be used to see how the individual fits deviate from this common fit.
Here is a workaround:
Before splitting the plot into subplots, generate a fit and save the formula to the table. Add the fitted data points and split the plot.
With the possibility to disab´ple the Wrap (or X /Y Group) variable for the Linear fit, the final plot could be generated directly with GraphBuilder without a woraround.
cool, isn't it?
Names Default to Here(1);
// generate the plot without splitting it
	myPlot= Data Table( "Big Class" ) << Graph Builder(
		Size( 582, 401 ),
		Summary Statistic( "Median" ),
		Graph Spacing( 4 ),
		Variables( X( :height ), Y( :weight ) ),
		Elements( Points( X, Y, Legend( 12 ) ), Line Of Fit( X, Y, Legend( 14 ) ) )
	myPlot << Update Element( 1, 1, 2, {Save Formula} );
// save the fit
:"Line of Fit(weight)"n << set name("common fit");
// use it in additional to the data points
myPlot << Add Variable({:common fit , Role("Y"), Position(1)});
// split the plot
myPlot << Add Variable({:sex, Role("wrap")})
4 Comments
hogi
Level XIII
In addition, for some variables, there are check boxes, but they don't have an effect -> enable them!
X=name IS DISABLED, but it's used to generate the plot.
Graph Builder(
	Variables(
		X( :sex ),
		X( :name, Position( 1 ) ),
		Y( :weight ),
		Overlay( :sex )
	Elements(
		Points( X( 1 ), Y, Legend( 1 ) )
hogi
Level XIII
SarahGilyard
Good suggestion Hogi. I've marked this for inclusion in the next prioritization survey. There are several wishes related to graph builder improvements that we could combine into a single initiative. We will discuss internally.
hogi
Level XIII
@SarahGilyard ,thanks,  wonderful : )
