Graph Builder Preferences: Middle 90% (or 99%)
☐ cool new feature
☑ could help many users!
☐ removes a „bug“
☐ nice to have
☐ nobody needs it
Some while ago, I found this post in the community:
In graph builder, is there a way to set the default color code gradient range to "Middle 90%"?
by @tsg.
Up to now, there was no reply - and I could not find a related wish ...
Possibility to set the default range of a color gradient to Middle 90%.
Alternative options: 1% - 99%?
Why is this idea important?
The middle 90% option is amazingly useful - outliers don't destroy the color settings. Especially for exploratory data  analysis of a "dirty" dataset - e.g. by using the Column Switcher!
But at the moment, the user has to enable the setting manually - and concerning Column Switcher it's disabled after every single switch. Argh!
The possibility to set the default range of a color gradient to Middle 99% would solve the issue
13 Comments
hogi
Level XIII
you are right, I edited the post:  no hidden data points.
One could argue that colors for out of range data points are misleading.
This might be the reason why the mode is just available "manually", but not by default.
big dots/labels: wishes from the JMP Wish List Prioritization Survey!
Kudos = 14 (black) -- or 17- 37 (labels)?
To fix the issue one can add a steep trend at the end of the color scale
to mark "out of range" points with another color:
ehchandlerjr
Level V
hogi
Level XIII
Alternatively, one can Show message if color range type set to Middle 90% -- I just uploaded a new version of  Graph Builder Toolbar with this feature : )
