  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Add "treat consecutive delimiters as one" to data import
Some data files we use that are generated by some equipment unfortunately saves the output using "tab" to make the formatting look nice when printed. Unfortunately, sometimes there's one tab, and sometimes there's two tabs, depending on the width of the contents of the field.
For example:
Row     Value1      Value2
1       1.2         6.2
2       12.5234213  1.2
3       0.1         2.2342
And in this contrived example, those spaces are defined with tabs. I'll type "\t" for each tab...
Row\tValue1\t\tValue2
1\t1.2\t\t6.2
2\t12.5234213\t1.2
3\t0.1\t\t2.2342
So JMP has no way to import that data directly with each value in the correct column. As a fix, I used Multiple File Import, imported Row Per Line strings, and used column formulas such as this:
cdt << New Column( "Gas1", Numeric, Formula( Word( 2, Regex( :Text, "[\s]", " ", GLOBALREPLACE ) ) ) );
But Excel has a "treat consecutive delimiters as one" in their import Wizard. If we agree that JMP is better than Excel, JMP should have this option, too!
2 Comments
Sarah-Sylvestre
Level V
hogi
Level XIII
Another workaround:
Instead of Regex, use Text to Columns.
Different than MFI this function - which vice-versa is not always what the user wants :)
Text To Columns: handle missing data correctly
