  • See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
Global Preference to Disable 'Fit to Window' in Graph Builder
As a heavy user of JMP, I frequently turn off the 'Fit to Window' option in Graph Builder to maintain consistent axis scaling across graphs. However, this setting must be manually adjusted for each graph.  I would like to request an option in the Preferences menu to globally disable 'Fit to Window' by default, streamlining the workflow and improving efficiency.
1 Comment
Status changed to: Needs Info
Hello! If I am understanding your request correctly, we already have this available in JMP. If you go to your JMP Preferences > Platforms > Graph Builder you should see a preference you can adjust for Fit to Window. Please let me know if this fulfills your request!
