Global Preference to Disable 'Fit to Window' in Graph Builder
As a heavy user of JMP, I frequently turn off the 'Fit to Window' option in Graph Builder to maintain consistent axis scaling across graphs. However, this setting must be manually adjusted for each graph.  I would like to request an option in the Preferences menu to globally disable 'Fit to Window' by default, streamlining the workflow and improving efficiency.
1 Comment
Sarah-Sylvestre
Level V
Status changed to: Needs Info
Hello! If I am understanding your request correctly, we already have this available in JMP. If you go to your JMP Preferences > Platforms > Graph Builder you should see a preference you can adjust for Fit to Window. Please let me know if this fulfills your request!
