Fit Y by X Bivariate - Auto-Scaling Axes
Hello,
I often generate multiple Bivariate plots from a dataset using a By variable. If I change the axis type (e.g., from Linear to Log) on one plot, I can then broadcast it to the other plots. However, when I do this, the scale range for the first plot also gets broadcast. I also don't want to set a one-size-fits-all scale. Can this platform be enhanced to allow interactively changing the axis type while still auto-scaling each plot based on its data? I know there are ways to do this with JSL but the specific request is to be able to do this interactively.
Thanks and regards
Mehul Shroff
