%3CLINGO-SUB%20id%3D%22lingo-sub-699411%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EFit%20Y%20by%20X%20Bivariate%20-%20Auto-Scaling%20Axes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-699411%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EI%20often%20generate%20multiple%20Bivariate%20plots%20from%20a%20dataset%20using%20a%20By%20variable.%20If%20I%20change%20the%20axis%20type%20(e.g.%2C%20from%20Linear%20to%20Log)%20on%20one%20plot%2C%20I%20can%20then%20broadcast%20it%20to%20the%20other%20plots.%20However%2C%20when%20I%20do%20this%2C%20the%20scale%20range%20for%20the%20first%20plot%20also%20gets%20broadcast.%20I%20also%20don't%20want%20to%20set%20a%20one-size-fits-all%20scale.%20Can%20this%20platform%20be%20enhanced%20to%20allow%20interactively%20changing%20the%20axis%20type%20while%20still%20auto-scaling%20each%20plot%20based%20on%20its%20data%3F%20I%20know%20there%20are%20ways%20to%20do%20this%20with%20JSL%20but%20the%20specific%20request%20is%20to%20be%20able%20to%20do%20this%20interactively.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThanks%20and%20regards%3C%2FP%3E%3CP%3EMehul%20Shroff%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-699411%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EBasic%20Data%20Analysis%20and%20Modeling%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EData%20Exploration%20and%20Visualization%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Fit Y by X Bivariate - Auto-Scaling Axes
Hello,
I often generate multiple Bivariate plots from a dataset using a By variable. If I change the axis type (e.g., from Linear to Log) on one plot, I can then broadcast it to the other plots. However, when I do this, the scale range for the first plot also gets broadcast. I also don't want to set a one-size-fits-all scale. Can this platform be enhanced to allow interactively changing the axis type while still auto-scaling each plot based on its data? I know there are ways to do this with JSL but the specific request is to be able to do this interactively.
Thanks and regards
Mehul Shroff
