%3CLINGO-SUB%20id%3D%22lingo-sub-699411%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAjuster%20Y%20par%20X%20Bivari%C3%A9%20-%20Axes%20%C3%A0%20mise%20%C3%A0%20l'%C3%A9chelle%20automatique%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-699411%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EBonjour%2C%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EJe%20g%C3%A9n%C3%A8re%20souvent%20plusieurs%20trac%C3%A9s%20bivari%C3%A9s%20%C3%A0%20partir%20d'un%20ensemble%20de%20donn%C3%A9es%20%C3%A0%20l'aide%20d'une%20variable%20By.%20Si%20je%20change%20le%20type%20d'axe%20(par%20exemple%2C%20de%20Lin%C3%A9aire%20%C3%A0%20Log)%20sur%20un%20trac%C3%A9%2C%20je%20peux%20ensuite%20le%20diffuser%20sur%20les%20autres%20trac%C3%A9s.%20Cependant%2C%20lorsque%20je%20fais%20cela%2C%20la%20plage%20d'%C3%A9chelle%20du%20premier%20trac%C3%A9%20est%20%C3%A9galement%20diffus%C3%A9e.%20Je%20ne%20veux%20pas%20non%20plus%20%C3%A9tablir%20une%20%C3%A9chelle%20universelle.%20Cette%20plate-forme%20peut-elle%20%C3%AAtre%20am%C3%A9lior%C3%A9e%20pour%20permettre%20de%20modifier%20de%20mani%C3%A8re%20interactive%20le%20type%20d'axe%20tout%20en%20continuant%20%C3%A0%20mettre%20%C3%A0%20l'%C3%A9chelle%20automatiquement%20chaque%20trac%C3%A9%20en%20fonction%20de%20ses%20donn%C3%A9es%26nbsp%3B%3F%20Je%20sais%20qu'il%20existe%20des%20moyens%20de%20le%20faire%20avec%20JSL%20mais%20la%20demande%20sp%C3%A9cifique%20est%20de%20pouvoir%20le%20faire%20de%20mani%C3%A8re%20interactive.%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3EMerci%20et%20salutations%3C%2FP%3E%3CP%3EMehul%20Shroff%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-699411%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAnalyse%20et%20mod%C3%A9lisation%20des%20donn%C3%A9es%20de%20base%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EExploration%20et%20visualisation%20des%20donn%C3%A9es%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Fit Y by X Bivariate - Auto-Scaling Axes
Hello,
I often generate multiple Bivariate plots from a dataset using a By variable. If I change the axis type (e.g., from Linear to Log) on one plot, I can then broadcast it to the other plots. However, when I do this, the scale range for the first plot also gets broadcast. I also don't want to set a one-size-fits-all scale. Can this platform be enhanced to allow interactively changing the axis type while still auto-scaling each plot based on its data? I know there are ways to do this with JSL but the specific request is to be able to do this interactively.
Thanks and regards
Mehul Shroff
