  • See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
File Open JSL: Add Edit
In JMP, File -> Open  for files of type JMP Scripts (*.JSL), the OPEN button has options for Open and Run.
Suggestion: add a third option: Edit
If the JSL file begins with \\!, Open and Run both run the JSL wiout an option of editing the file without running it first. While you can edit a JSL from the recent files list, you had to have opened or run it first before the recent files list is populated.
3 Comments
gzmorgan0
Super User (Alumni)
Ther is a preference in JMP to specify to not run scripts automatically.  Main Menu > File > Preferences > select Windows Specific (or I assume  on a Mac there is something specifivc to the MAC). Make sure the highlighted preference is unchecked. Then teh default behavior is to open and edit.  A script is only withe the special key or , <<Run message.
Jeff_Perkinson
Community Manager
If you hold the Ctrl-key down when you click the Open in the File->Open dialog when opening a script with the auto-submit indicator (i.e., //!) it will open in the script editor instead of running.
Ryan_Gilmore
Community Manager
Status changed to: Archived
