Extend Fit Ordinal Logistic by the following two features:
- Add the Odds Ratios together with 95%-CIs,
- Add a test to check the proportional odds assumption.
JMP Pro 17
It is elementary to view and be able to save the CIs in an ordinal logistic regression
But instead you archived this request
Can CIs be added please?
Prof. Eli Geffen
I would like supporting the preceding request but for JMP 17 and not just JMP Pro 17
