Hi JMP Community,
I would like to propose an enhancement to the scripting of Graph Builder plots which would enable the addition of simple graphic elements (line, boxes, arrows...) to the Axis region (AxisBox) of the graph (the current GB scripts are limited to the GrahBox region).
Here is an example of the type of enhancement I have in mind:
