Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
Document and support the DisableJMPPro() function. For those individuals that support a community of JMP users, some that do not have JMPPro, being able to develop and/or test standard JMP programs is important.
Hi @txnelson, thank you for this suggestion. Unfortunately, DisableJMPPro() does not completely disable everything, so this is not a function we feel comfortable documenting, publicizing or formally supporting. A more reliable solution is to either run the two products side by side or to swap out the license files.
Changing the status of this request, but we're happy to reopen and explore other potential solutions.
