Display of Data Size Limit When Using JMP Live Auto Refresh
Hello,
I recently discovered that there is a data size limit (50MB) for each dashboard on JMP Live. In this particular case, the size increased rapidly due to poorly written code, but it led me to realize that—even though such cases are rare—other properly functioning dashboards could also eventually exceed the 50MB limit as more data accumulates over time. This could cause them to stop working unexpectedly, so I would like to suggest a few improvements for better management.
First, it would be helpful if administrators could see the size status of each published dashboard at a glance—perhaps through an icon or a gauge. Also, in each dashboard, there is a "Data" tab on the left-hand side. Currently, the data size can only be confirmed after downloading the file. I believe it would be more convenient if the data size could be displayed before downloading.
I look forward to seeing continued improvements to JMP Live.
Best regards,
Dongjin Kim
2 Comments
Hello Dongjin Kim,
Regarding the size limit of 50MB, the JMP Live admin at your organization can increase this limit if necessary.  On the "Admin" page, there is a "Settings" tab.  On that tab, there is a "Limits" section.  In that section, there is a setting called "Maximum post size MB" which is set to 50 by default, but can be increased.
Regarding your other suggestions, thank you, we love getting suggestions from users!  Our Product Management team will evaluate these.
  • administrators could see the size status of each published dashboard at a glance—perhaps through an icon or a gauge
  • data size could be displayed [in the "Data" tab of a report] before downloading
Thank you for submitting this request!
