  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Degradation >> Stability Analysis Column Switcher
What inspired this wish list request? Please describe the current issue that needs improvement or the problem to be solved that is not easy or possible right now, with an example use case. The column switcher isn't always available and when it is available (specifically when using a "by" variable it does not update the spec limits when switching between stability parameters
What is the improvement you would like to see? Please describe the idea for improving JMP. Please include mock-ups, wireframes, screenshots, scripts, other documents or examples from other software that help describe the change you would like to see. It would be great to use the column switcher when running stability with or without a by variable and have it rerun the analysis based on the correct specs in the column properties.
Why is this idea important? Please describe the value to you and/or other users if the idea is implemented (for example, ease of use, must have,…). Currently have to create a script for every parameter of the stability program (14+ parameters) for each product in our pipeline it also makes it difficult to easily bulk export the information into a single document. it would be a huge timesaver to utilize a column switcher and add a journaling script to automate this process as can be done for other platforms.
2 Comments
Hello CKII, Thank you to have submit your wish. We have acknowledged your request.
JNuhn
Level II
This is a huge issue for us and keeping us in JMP 17 since column switcher was removed from the stability module  in JMP 18 and isn't available in JMP 19.
