  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Keep Comments in Columns
I have some convoluted formulas that I'm stuggling to keep straight and I don't want to make my column names longer than they already are. I want to remember what I was working on when I come back to it in a few days. I'll often put some comments in the source script (or just a blank script) and wanted to do the same.
When you comment in a column the comments are dropped. Can we keep them?
Why is this idea important?
It'll allow me to come back to previous work with a better idea of what I've done. Sometimes it can feel like I need to start from 0 if I can't exactly remember where I was. And other people will have more clues when looking at one of my files.
3 Comments
hogi
Level XIII
you can use JSL code to add a pseudo comment, e.g.
mycomment = "this is a comment to better understand the ideas behind the  formula when I come back later";
not ideal - but maybe good enough as a workaround till there is an official solution.
SarahGilyard
Status changed to: Needs Info
Thank you for posting. If you use the Notes feature under the Column Properties, does this serve the purposes you need?
hogi
Level XIII
No, unfortunately not.
we want to document the JSL code in the Formula editor, we don't want to write a note about the column in general.
The notes in the column properties are too far away from the Formula Editor.
